(May 1, 2013) POOLSPAFORUM.COM SITE UPGRADE!
Members, We are in the beginning stages of a major site upgrade to maximize your online experience.  This includes new content, special reports, mobile connectivity, etc. We've even adding several new layers to protection to help insulate the forum from hackers and spammer attacks that are constantly a challenge.  Thank you and we appreciate your loyalty to the best community on the web!
Epson Salt In Spa
  • Please log in to reply
5 replies to this topic
#1 countrygal
countrygal
    Junior Member
  • Members
  • PipPip
  • 24 posts
  • Gender:Female
Posted 28 November 2007 - 09:47 AM
I know that using epson salt in bath water is very soothing and leaves your skin soft. Does anyone know if it can be safely added to the spa?
#2 chem geek
chem geek
    Wizard of Water
  • Members
  • PipPipPipPipPip
  • 4,351 posts
  • Gender:Male
Posted 28 November 2007 - 10:13 AM
See this thread for a discussion of various additives to water including aroma therapy and bath salts (including Epsom Salt). The main problem is that the 2% (20,000 ppm) level of salt that is normally recommended to get the main benefit is a level of salt that is corrosive to metal. If you have a copper heat exchanger in your gas heater for the spa, then I would say that this level of salt would be out of the question. If it's titanium or a cupro-nickel alloy more resistant to corrosion, then that's safer though there is still the pump to consider. If you use a lower level of salt staying below the 3000 ppm level found in saltwater chlorine generator (SWG) pools, then that would be safer. Any level of salt up to around 1500 ppm is probably OK. Also, if you keep the pH higher -- always above 7.5 -- then that reduces the risk of corrosion.
To get to the 3000 ppm salt (sodium chloride) equivalent for Epsom Salt (Magnesium Sulfate Heptahydrate) in 350 gallons which is equivalent to 8.7 pounds of sodium chloride salt would be 36.7 pounds of Epsom Salt (again, in 350 gallons). I would add half that amount and see how it feels and I wouldn't add more than the 36.7 pounds per 350 gallons. You can, of course, add even less to see if smaller amounts give any benefit. If an average sized bathtub holds 50 gallons, then 3000 ppm would be 5.2 pounds of Epsom Salt so you can see if that is what was recommended for your bath and if less is required, then you can scale down accordingly. I've seen recommendations (here for example) of 2 cups of Epsom Salt added to a bath (say, 50 gallons) so that would result in around 1 pound so that's around 600 ppm (sodium chloride equivalent) which is a low amount of salt and should be no problem in a spa (so that would be equivalent to around 14 cups of Epsom Salt in 350 gallons).
You are able to use Epsom salt in a bathtub without problems because you regularly drain the water out of the tub. The spa, however, will keep the salt until you next drain/refill which may be many months and if you always use salt then the exposure will be continuous.
One final word of caution. Be careful not to splash out or drip the water onto unsealed concrete or stone surfaces (or if you do, rinse it off to dilute it). When the water evaporates, it will leave salt and if there are any cracks or crevices, the evaporation will cause the salt to crystallize in those cracks which creates high pressures. Unfortunately, Epsom Salt (magnesium sulfate) creates a very high crystallization pressure (higher than regular sodium chloride salt) so could damage concrete and stone surfaces over time.
Richard
#3 countrygal
countrygal
    Junior Member
  • Members
  • PipPip
  • 24 posts
  • Gender:Female
Posted 28 November 2007 - 12:44 PM
Thanks for the information Richard. I need to drain the spa in about 2 weeks anyway so I think I will try adding some Epsom Salt in small amounts about 2 cups per day, not to exceed a total of 14 cups. I will "test" each night to see how much it takes to get any noticeable results. If nothing happens or if the water gets a bad reaction I'll drain (have to anyway) and scratch this idea. Thanks again for sharing your knowledge.
#4 spa enjoyer
spa enjoyer
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 01 December 2009 - 12:12 AM
QUOTE (chem geek @ Nov 28 2007, 10:13 AM) <{POST_SNAPBACK}>
Richard
Thanks, Richard. I'm new to the Pool and Spa Forum and this info is exactly what i needed!
#5 christo
christo
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 31 January 2012 - 07:33 AM
See <a href="http://www.poolspafo...opic=9890&st=0" target="_blank">this thread</a> for a discussion of various additives to water including aroma therapy and bath salts (including Epsom Salt). The main problem is that the 2% (20,000 ppm) level of salt that is normally recommended to get the main benefit is a level of salt that is corrosive to metal. If you have a copper heat exchanger in your gas heater for the spa, then I would say that this level of salt would be out of the question. If it's titanium or a cupro-nickel alloy more resistant to corrosion, then that's safer though there is still the pump to consider. If you use a lower level of salt staying below the 3000 ppm level found in saltwater chlorine generator (SWG) pools, then that would be safer. Any level of salt up to around 1500 ppm is probably OK. Also, if you keep the pH higher -- always above 7.5 -- then that reduces the risk of corrosion.
To get to the 3000 ppm salt (sodium chloride) equivalent for Epsom Salt (Magnesium Sulfate Heptahydrate) in 350 gallons which is equivalent to 8.7 pounds of sodium chloride salt would be 36.7 pounds of Epsom Salt (again, in 350 gallons). I would add half that amount and see how it feels and I wouldn't add more than the 36.7 pounds per 350 gallons. You can, of course, add even less to see if smaller amounts give any benefit. If an average sized bathtub holds 50 gallons, then 3000 ppm would be 5.2 pounds of Epsom Salt so you can see if that is what was recommended for your bath and if less is required, then you can scale down accordingly. <b>I've seen recommendations (<a href="http://www.epsomsalt...usage_tips.htm" target="_blank">here</a> for example) of 2 cups of Epsom Salt added to a bath (say, 50 gallons) so that would result in around 1 pound so that's around 600 ppm (sodium chloride equivalent) which is a low amount of salt and should be no problem in a spa (so that would be equivalent to around 14 cups of Epsom Salt in 350 gallons).</b>
Richard
Sounds like I have a lot of reading to do. What comment can you say regarding the sanitation? Is Epson salt good enough or should another product be used?
Christo
#6 waterbear
waterbear
    Village Idiot ;)
  • Moderators
  • PipPipPipPipPip
  • 3,212 posts
  • Gender:Male
Posted 31 January 2012 - 07:47 AM
Christo
Epson salt (magnesium sulfate) is not a sanitizer. Sodium chloride (salt) by itself is not a sanitizer. On a tub fitted with a salt water chlorine generator the sodium chloride is used to generate chlorine by electrolysis . Chlorine is a sanitizer.
There are only 4 EPA approved sanitizers for hot tubs:
Chlorine (either manually added or generated)
Bromine (either manually added or generated--in the same way as chlorine but by using sodium bromide instead of sodium chloride)
Silver ions/MPS (Nature2). However instructions MUST be followed to the letter or many problems have been reported.
Biguanide ("non chlorine/non bromine" sanitizer system)--expensive and has its unique set of problems that tend to drain your wallet to fix. Also, it uses concentrated hydrogen peroxide as a 'shock' and it can be irritating to both skin and lungs.)
I would consider either of the first two for sanitation.
If you look in the hot tub water chemistry section of the forum you will find instructions on both chlorine and bromine 'pinned' to the top of the section.
You can also add 50 ppm borate to the water (borax and acid to bring the pH back in line) which not only has a skin softening and bath salt effect, it also helps maintain the pH and it is a highly recommended additive.
There is also a commercial spa product for adding borate, Proteam Gentle Spa (which also has a fragrance).
Borate is NOT a sanitizer and is used in conjunction with one of the 4 sanitizers above!
Board Moderator
website security
