I had some trouble at the beginning of the season with low pH readings, 6.8, but after slowly adding pHPlus I'm now at 7.4 pretty much. It reads 7.2 with the strip and 7.6 with the kit. Total alkalinity is between 80 - 100, depending on which test I use (strip or kit).
My problem is the FC and CYA. The trichlor, from what I understand, has the stabilizer in it and the feeder says on its lid to use only trichlor. The water is clear and feels smooth and silky, no problem there. Chlorine smell is minimal to none. My skin does not feel dry although my eyes burn a little.
The FC reading is 0 - .5 with the strip and 1.0 with the reagent kit. The 'standards' given by the test docs say I should have 1.5 to 3.0 free chlorine. The CYA reading is 0 on both tests.
I don't really understand why I can't get the FC/CYA readings to anything near 'normal' and yet the water is clean. Should I shock the pool to bring the Cl level up? Or should I just not mess with it on the premise that it ain't broke?
We're new to pool ownership and maintenance and want to do it right because it's a pretty expensive toy.
Thanks for your input,
Anka
