FixItGirl Posted July 21, 2013 Report Share Posted July 21, 2013 I need some help trouble shooting this error message on my Jandy Heater!!!!! "Shorted H20 Sensor" I have replaced the Water Sensor which is in the pipe between the filter and the heater - (thinking this was what the error was regarding, I should have known better) Is there a sensor actually inside the unit which I can replace? Or could this be a board problem...... Heater is 3 years old..... Jandy LRZ 400ep Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 22, 2013 Report Share Posted July 22, 2013 Temp sensor is located in the inlet/outlet header. disconnect leads and measure resistance. Should be somewhere between 19.898K ohms (50 degrees) - 5.327K ohms (104 degrees). Although, if you are getting a failure code, it is probably open/disconnected. Either a failure proper, or possibly a pest has chewed the wires. BTW, if you have a salt system, the temp sensor may have failed due to the salt water. Jandy provides for this specific condition, a salt temp sensor at over twice the cost of a regular one. Quote Link to comment Share on other sites More sharing options...
FixItGirl Posted July 22, 2013 Author Report Share Posted July 22, 2013 Thanks so much for reponding Spa Guru! The temp sensor for my pool and jacuzzi works properly - I am only getting the error message on the Jandy heater itself. So there is a different temp sensor in the heater unit itself? (I am not familiar with the heater, never had issues before) I replaced the temp sensor itself (it has failed before, so that was my first guess) The temperature is accurate on my Hayward Aqua Pod and Goldline panel box - I don't get any errors here. The jacuzzi was not heating up, so I looked on the heater panel itself - it has the error - so the rest of my system does not recognize any issues..... So for my clarification - I have the air temp sensor - the water temp sensor on the top pvc pipe between my filter and heater... Both of which are working.... I will go down and open the heater when I get a chance to see if I can figure out what I am looking for inside of it. It is something wrong only on the heater panel - no errors show with the rest of my system It is a salt water pool..... I appreciate your help. This is driving me crazy, as it is the first issue I have not been able to fix on my own! Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 24, 2013 Report Share Posted July 24, 2013 So there is a different temp sensor in the heater unit itself? Yes. Quote Link to comment Share on other sites More sharing options...
FixItGirl Posted August 17, 2013 Author Report Share Posted August 17, 2013 Can you help me to find it? Is it similar to the other sensors? Coincidentally this happened after we our heater propane tank filled - Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted August 23, 2013 Report Share Posted August 23, 2013 Temp sensor is located in the inlet/outlet header of the heater. Look for the wires in that area, and they will lead to the sensor Quote Link to comment Share on other sites More sharing options...
anglenasalt Posted January 31, 2014 Report Share Posted January 31, 2014 Jandy provides for this specific condition, a salt temp sensor at over twice the cost of a regular one. BTW, if you have a salt system, the temp sensor may have failed due to the salt water. Quote Link to comment Share on other sites More sharing options...
