bradley8002 Posted May 1, 2014 Report Share Posted May 1, 2014 So I just bought a house that has an in ground pool. I've been trying to figure everything out on my own and am not having much success with which Jandi valve controls what. I have 2 pumps like I said. Ones the main pool pump that has 3 pipes going into it all with separate valves. The other is my vacuum pump for the pool vacuum. What I'm having problems with is what valve controls what. I know 2 of the valves control either skimmer individually so you would think the third one would be piped to the drain. But when that valve is on and the other 2 are off both skimmers pull harder than it does when the 2 that control the skimmer individually. IDK if that makes any since but some insight into my problem would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted May 1, 2014 Report Share Posted May 1, 2014 Post a pic of the plumbing at the equipment. Quote Link to comment Share on other sites More sharing options...
