vadoctor Posted May 13, 2015 Report Share Posted May 13, 2015 I am replacing a sundance spa 2 speed pump and was wondering if i should use teflon paste on the wet end of the pump ( male threads ) when i am tightening the pvc nut. i can't find it mentioned anywhere but it seems that it would lessen the chance of a leak. or is this a bad idea? Quote Link to comment Share on other sites More sharing options...
SpaSage Posted May 16, 2015 Report Share Posted May 16, 2015 You shouldn't need to use teflon on the 2" connections on the wet end of the pump. You do want to use a bit of teflon on the nut(s) or bleeder connections. These will be much smaller, 1/4"-ish. Quote Link to comment Share on other sites More sharing options...
Roger Posted May 18, 2015 Report Share Posted May 18, 2015 I like to use Majilube on all threads. Teflon take on some along with lube. Quote Link to comment Share on other sites More sharing options...
dg98adams Posted June 23, 2015 Report Share Posted June 23, 2015 I believe the ring should be clean and dry. Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 24, 2015 Report Share Posted June 24, 2015 O-rings can be lubed, but gaskets should be clean and dry- it depends on what yours has. Also, no need to use teflon or lube on the pump union threads- it's a compression fitting, the threads are meant to tighten the O-ring- the threads are NOT waterproof, nor are they meant to be- that's the job of the O-ring or gasket. Quote Link to comment Share on other sites More sharing options...
