cjwickham Posted June 1, 2014 Report Share Posted June 1, 2014 Hi folks. First hot tub that came with a new house we've just bought. The tub turns on ok and flow/jet 1 pump works fine and circulates until you press jet 1 switch and then it trips a switch/fuse in the house. Any ideas at all as I am new to hot tubs? Jet 2 is ok as the second pump kicks into life. It's a Balboa Spaform SF100 so quite an old one we've been told? Cheers. Colin. Quote Link to comment Share on other sites More sharing options...
cjwickham Posted June 1, 2014 Author Report Share Posted June 1, 2014 The pump by the way is a hydro air magnaflow 440. I've also changed both capacitors in the pump as 1 had burnt out. Quote Link to comment Share on other sites More sharing options...
