stbear007 Posted November 12, 2014 Report Share Posted November 12, 2014 Hi how can I tell by looking through window if ozonator chip is no longer any good ? Should it be depleting ? It's a del ozonator cds-16. I have searched for 2 weeks to find a answer but all I see so far is the one time ozone reader tester. Many thanks on this questions answer. Quote Link to comment Share on other sites More sharing options...
Spanky Posted November 13, 2014 Report Share Posted November 13, 2014 If the chip is working you will see a purple glow in the window. Make sure the system is calling for the ozone to be ON. Many systems turn the ozone off every half hour and most systems turn the ozone off as soon as there is any control input. ie.. the system detects you're using the tub and will not turn the ozone back on untill 20-30 mins after the last control input. This is because breathing ozone is a health hazzard therefore most tubs turn the ozone off when someone is using the tub. There is usually some form of indicator on the topside control that indicates the system has turned the ozone ON. Next check that the CD unit is receiving 110V, most systems hav some form of inline fuse protection. If everything else checks out and you don't see a purple glow in the window then yes the chip is most likely burned out. Quote Link to comment Share on other sites More sharing options...
