Venom Posted March 30, 2014 Report Share Posted March 30, 2014 I have a Balboa controller and I have searched and searched and cannot find a conclusive answer to this, someone PLEASE help me. What the heck does the filter cycles mean? If I set my spa on F2, does that mean in runs 2 filter cycles a day? How long will it run? I'm trying to find the optimal setting for my tub. I currently have it on EC (Economy Mode) and F2. I want the tub to stay fairly close to the set temperature so when I get home from work I don't have to wait hours for it to heat up and get in. Also, when I get out, what do I need to due to set in back into the mode, just turn it to low speed? Thanks, Confused in Tennessee Quote Link to comment Share on other sites More sharing options...
Hotrod Posted March 31, 2014 Report Share Posted March 31, 2014 F2 is a 2 hour filter cycle.If I am not mistaken you have a choice from 2 to 12 The time you choose will I think depend on how often its used and by the number of peopleI would also suggest you put it in standard mode if you want it ready for use any time. In Economy mode the tub only heats to set temp during the filter cycle. Standard mode will maintain set temp.Once you have set the mode thats it use the tub when done turn the jets will shut off after 15 minutes and tub will circulate on low speed or just push the massage button and thats it Hope that helps. Quote Link to comment Share on other sites More sharing options...
