justme0987 Posted October 26, 2015 Report Share Posted October 26, 2015 I have a hot tub, I noticed that the motor started to make noise when it turns on. I took the motor and pump out and replaced the bearing and the seal. I installed it back. There is no noise now and no leak. I connected the motor electric wires exactly the same way they were before. After connecting the power, there is light in the LCD, then I pushed the jet bottom, I felt that the motor tried to start with the low speed, but there was not jets coming. Then I pushed the same button again then the high jets started and the water gradually heated to the set temp of 102. I left the spa for 6 hours and came back to chack on it, there is error message HH, the water is just warm. I pushed the jet button twice then the fast jet started again, then a temp of 106 showed in the LCD, after a minute the real temp showed as 98, gardually the temp started to go up to the set temp of 102. It appears that the slow jet tries to start spontaneously but it is not moving the water inside the hot top, you can hear it's noise. When I push the jet button once I can hear noise but no slow jet, when I push it again the fast jet starts and strong jets , Now when I push the button again the slow jet will work and everything looks fine. This goes on until the set temp is reached. Any advice is greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
Andy Green Posted October 26, 2015 Report Share Posted October 26, 2015 Just out of curiosity did you reopen the gate valves to allow the water to flow through the system? Have forgotten to do this once myself and fried the high limit sensor. Quote Link to comment Share on other sites More sharing options...
justme0987 Posted October 26, 2015 Author Report Share Posted October 26, 2015 Yest there are three gate valves in my system , all opened Quote Link to comment Share on other sites More sharing options...
