shaklee3 Posted December 14, 2014 Report Share Posted December 14, 2014 Hi, we inherited a hot tub after buying a house, and we finally decided to try it for the first time in over 2 years. After cleaning it out and filling it up, it seemed to be working well. However, I looked in the maintenance panel and see a leak from one of the pipes. It appears to be a coming from a clamp from the computer to the pump. I've linked to two images -- one showing the exact location of the leak, and one showing a picture. Should I put some pipe sealant on this or get a new clamp? http://s7.postimg.org/5rfu1eu5n/leak.png http://s7.postimg.org/x4l0w60q3/leak.jpg Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted December 14, 2014 Report Share Posted December 14, 2014 That's a union. I'd try simply tightening it up (with your hand...NO wrench). Quote Link to comment Share on other sites More sharing options...
shaklee3 Posted December 14, 2014 Author Report Share Posted December 14, 2014 It looks like it has a Phillips screw on it. Leave that and just try hand tightening? I can send a better picture if it helps Quote Link to comment Share on other sites More sharing options...
Markee Posted December 15, 2014 Report Share Posted December 15, 2014 Tightening it or putting pipe sealant is only a band-aid fix. All you need to do is buy some new heater gaskets and install them. There is one on each side of the heater, I would recommend changing them both. Quote Link to comment Share on other sites More sharing options...
shaklee3 Posted December 16, 2014 Author Report Share Posted December 16, 2014 Thanks markee. Can you point me to where to buy one? I don't see something that looks like these on any of the spa parts sites. Quote Link to comment Share on other sites More sharing options...
Markee Posted December 16, 2014 Report Share Posted December 16, 2014 Where do you live at? Is there a local Marquis dealer? Quote Link to comment Share on other sites More sharing options...
shaklee3 Posted December 17, 2014 Author Report Share Posted December 17, 2014 I'm in San Diego. I searched Google and didn't find anything obvious next me. It's a 2003 Reward. Quote Link to comment Share on other sites More sharing options...
shaklee3 Posted December 17, 2014 Author Report Share Posted December 17, 2014 Do you think this and a gasket would work? http://www.amazon.com/Split-Heaters-Screws-Waterway-400-5421/dp/B004VTGGOK Quote Link to comment Share on other sites More sharing options...
Markee Posted December 17, 2014 Report Share Posted December 17, 2014 You shouldn't need a new union, the existing ones should be fine. You just need 2 heater gaskets. Check your messages, I sent you my contact info. I can mail you some of the gaskets. Quote Link to comment Share on other sites More sharing options...
