Newtoblog Posted August 18, 2013 Report Share Posted August 18, 2013 I am new to blog, I have an in ground 15000 gal pool / spa combination. Pool is 6 years old and has been working well until recently. The spa and pool are on the same level and the spa has a positive flow that circulates water into the pool. I find that water is not flowing from the spa into the pool under normal operation. The spa works fine when placed in spa mode. Suspect the spa bypass valve but would like some suggestions Thanks, Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted August 23, 2013 Report Share Posted August 23, 2013 Suspect the spa bypass valve... Me too. Can you post a pic of the spa by-pass plumbing? www.photobucket.com Quote Link to comment Share on other sites More sharing options...
Blue88 Posted September 18, 2013 Report Share Posted September 18, 2013 I need help staying at daughters house sitting and heated the hot tub after pool guy showed me but this morning no water in the hot tub it drained to pool what do I do? Obviously one of the values isn't in right spot can you help ? Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted September 26, 2013 Report Share Posted September 26, 2013 When switching from spa back to pool, you probably missed rotating the suction side valve back to "pool". Quote Link to comment Share on other sites More sharing options...
Newtoblog Posted September 26, 2013 Author Report Share Posted September 26, 2013 Sorry for not getting back on the blog sooner. I went through many suggestions from my pool dealer that made sense 1) clogged jets 2)Broken or clogged by pass valve 3) Jandy valves not in proper direction I finally was able to diagnose the problem as the jandy valve that is located on my pool and spa suction. I noticed that my skimmer kept working while I placed the system in spa mode which normally didn't happen before. When I removed the actuator from the valve the stem fell away in pieces. So it never fully closed and caused some suction from spa thus empting the spa. I just replaced the diverter and O rings and it is working like new. Cost me $60 bucks and about an hours time including going to pick up new parts at my pool supply store. I was lucky that they were in stock Quote Link to comment Share on other sites More sharing options...
