jmardis Posted June 23, 2015 Report Share Posted June 23, 2015 Hello everyone, I have a question about piping configuration for my inground pool. I noticed the other day when I plug a couple of the jet ports on my spa, the water ejects from a pipe sticking out of the ground that is next to the spa. Upon closer inspection of this pipe, I noticed it was capped but then also has cut marks as if if it was accidentally cut. Is this pipe necessary or was this a piping configuration mistake? If its a mistake, can I cut and cap this pipe? Take a look at the pictures here: https://drive.google.com/folderview?id=0ByEuLnKme2gaLWJEcU1BSWNfQnM&usp=sharing Thanks, Josh Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted June 24, 2015 Report Share Posted June 24, 2015 That is where the air in your jets comes from. It was cut like that on purpose. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted June 24, 2015 Report Share Posted June 24, 2015 And the way your "plugging" the jet, you're simply forcing, or redirecting the water back through the air intake. What you have is supposed to be exactly the way it is...it's not malfunctioning in any way. Quote Link to comment Share on other sites More sharing options...
jmardis Posted June 25, 2015 Author Report Share Posted June 25, 2015 That explains it, thanks all for the feedback! Quote Link to comment Share on other sites More sharing options...
