Hot Springs Red Light Flashing, Fixed.
philodog
I bought a used Jetsetter, cleaned it up, replaced the circ pump and ozonator and it was working fine except it would shut down and flash the dreaded red light for no apparent reason. After trying all the basic fixes with no luck I started noticing it only did it when the control panel was bumped. Taking the cover off and randomly bumping components I narrowed it down to one of the connections from the heater to the control panel. Opening the connection I noticed one of the female bullet connections was pried apart slightly. I pushed it together with two tiny screwdrivers and the problem was solved. I don`t know the function of this connector but just a slight break in the current shut off the heater. Hopefully these Picasa pics will work. Just wanted to post this to hopefully help others as I have been helped by this forum.
https://picasaweb.google.com/107536012510809445934/April102014#6000789169103902098
https://picasaweb.google.com/107536012510809445934/April102014#6000789169827646370
