christiffa25 Posted June 24, 2015 Report Share Posted June 24, 2015 My tub is running in Econ mode and I don't appear to be able to change it to standard mode. It's a balboa 2005le pack with sensor and pressure switch in heater. 2 Speed pump and the old white 6 button balboa control panel. Jets, blower, Mode, light, cool and warm. I press Mode it flashes Econ but any other button presses does not change it to std or slp. I've also tried cool then mode and still doesn't change it. The light doesn't appear to be working either. The light on the button works and you hear a relay click but light doesn't come on.....Wondering if connected?? Any ideas anyone of either the problem or some suggestions of what combination of buttons I could try to change modes. Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 25, 2015 Report Share Posted June 25, 2015 try alternating temp, then mode, then temp, then mode, pressing each only once. Quote Link to comment Share on other sites More sharing options...
christiffa25 Posted June 25, 2015 Author Report Share Posted June 25, 2015 No that doesn't work either mate. When I hit cool or warm after or before mode it just changes the temp setting up or down a degree. Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 29, 2015 Report Share Posted June 29, 2015 Try alternating other buttons with the mode button. One of them should do the trick. This is done so you don't accidentally change it out of whatever mode you're in, simply by hitting the mode button. Quote Link to comment Share on other sites More sharing options...
