Nener Posted July 3, 2015 Report Share Posted July 3, 2015 I have a jandy LXI pool heater. The heater is around 6 yrs old, it was working fine in the spring. Now when I turn it on its not doing anything at all, after a few minutes it says ign control fault. I've tried everything to get it working but doesn't seem to be any different. The led indicator on ignition control module is not giving any fault code either. I was thinking either the ign control module is bad or the transformer! Anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
Bugman1400 Posted July 13, 2015 Report Share Posted July 13, 2015 Does the fan come on? If not, perhaps you should use a jumper to see which safety switch is bad. Quote Link to comment Share on other sites More sharing options...
