Hughescorp Posted August 31, 2014 Report Share Posted August 31, 2014 My filter pump stops running mid program. I have a 6-8 hour program set that stops running about half way through the programmed filter pump cycle. It will restart after an hour or two spontaneously. Even with turning off the pump, then restarting it, it will not run. It make the audible noise from the controller announcing cycle started. About two months ago my son pulled the vacuum out of the pool while filter pump running and left it out for a period of time. It was not producing suction. Once colored it began to work again. Could this break in pump function be related to overheating? It works great on a cold start. Quote Link to comment Share on other sites More sharing options...
