Kimberly Dukes Posted September 12, 2014 Report Share Posted September 12, 2014 It is Winter time and I want to close swimming pool but as it is my first year to use the swimming pool so I have a question that how to drain all water and what precautions should i use? Some people suggest me to drain all water and some say do not. So I am little confuse that what to do now? Can anyone share his experience? Hot tub in Kelowna really cool and I recommend everyone to get it for their home. Thanks in advance Quote Link to comment Share on other sites More sharing options...
alexMAT Posted September 12, 2014 Report Share Posted September 12, 2014 i am assuming this is an Above ground pool, this is what i recommend to my folks, i guess someone else can also chime in here and help you with this... *POOL SHOULD NOT BE COMPLETELY DRAINED* Check Manufacturers instruction on how to close your pool to protect it in the cold winter months. For above ground pools with a vinyl liner, a dry pool may cause tearing and cracking due to the cold weather, which can potentially damage the Linear beyond repair. Following steps can help in closing the pool for the winter 1. Clean up the pool and the surrounding area so as to be free of dirt, debris, leaves, branches and other materials that could get blown into the pool and potentially change the chemistry of the pool water. Scrub off the walls, surfaces and then with the help of a hand held pool vacuum or an automatic pool cleaner, remove all dirt and debris. 2. Verify pool equipment and ensure there is no severe damage or heavy wear and tear before the temperature start to decrease. Repair anything that is damaged and look out for cracks and tears in the pool liner or plumbing equipment. 3. Add the right Chemicals for winterizing (closing the pool for winter). After 24 hrs. Check the pool pH and alkalinity levels or as recommended on the winterizing kit. 5. Run the Filtration System for an hour after adding the pool chemicals. The water circulation will help to cleaning any leftover dirt and evenly disperse the chemicals. 6. Lower the Water level to be below the skimmer. Read the manufacturers recommendations for lowering the water level in your pool and make sure it is about two inches below the surface of the skimmer. 7. Clean the Filters. For D.E filters, Backwash the D.E. and clean out the grid and the inside of the tank For Cartridge filters, make sure to clean the cartridge and the inside of the tank For Sand filters, run an extra-long backwash to thoroughly clean the sand. Now Remove all filter hoses, remove the drain plugs from the pump, filter, and heater, to ensure no excess water is trapped in the system. 8. Store all equipment including pool ladder, pool steps, pool lights and other accessories in a safe and dry place for the rest of the time. 9. Winter Pool Cover to be installed as per manufacturers directions carefully, and take the time to spread the cover evenly across the surface of the pool. 10. And some Care, during the winter season keep it clean of any debris, leaves, branches, snow or ice accumulation on the cover. It may cause the cover to weigh down over time or may damage the cover which can be very difficult to fix. Quote Link to comment Share on other sites More sharing options...
