RGiroso Posted July 6, 2014 Report Share Posted July 6, 2014 The hot tub has been running for about a year. We noticed one night the power light was flashing. The water wasn't up to from, jets and light were not working either. Pulled the power cord, took out filters and pushed reset on the heater. This fixed the problem for about 24 yes. Followed the same procedure again. This time the power light only stayed on for 2 minutes. Tried a third time, when it kicked off that time, the light flashed a couple of times but now burns steady but we have no power to the tub. Any ideas?? Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted July 7, 2014 Report Share Posted July 7, 2014 On this model the power light flashing is a high limit trip. The normal things to look for, dirty filter, poor flow from the circ. pump or dead circ. pump, restricted flow in the heating system, bad high limit to start with. Normally with steady power light the spa should have all functions working but the only time I have seen this if someone does a fast power reset this can make the main board not to function correctly. Turn off the power for 30 seconds this will allow for a proper reset of the main board. Quote Link to comment Share on other sites More sharing options...
