ibrocn Posted July 25, 2016 Report Share Posted July 25, 2016 The heater in my Dynasty spa appears to be leaking at both ends. One end shows some corrosion (see pic linked below). Do you think I just have a bad seal or is my heater going to need replaced (it still heats)? https://1drv.ms/i/s!Auc1jxKdlPzjteFz82C_KlpPQpywag Quote Link to comment Share on other sites More sharing options...
KyleCT Posted July 25, 2016 Report Share Posted July 25, 2016 Looks like you just need new heater gaskets, call the guys over at hot tub discounts, they will have everything you need. Kyle Quote Link to comment Share on other sites More sharing options...
Cusser Posted July 29, 2016 Report Share Posted July 29, 2016 Did you try tightening the big plastic "nut" a hair ? Quote Link to comment Share on other sites More sharing options...
ibrocn Posted July 29, 2016 Author Report Share Posted July 29, 2016 KyleCT & Cusser - Thank you both for the replies! I tried to tighten the big plastic "nut", but that didn't stop the leak unfortunately. I was worried about tightening it too much and cracking the plastic. I sent an email to hottubdiscounts.com about heater gaskets based on Kyle's suggestion. I haven't heard back so I'm planning to call them today. Thanks! Brian Quote Link to comment Share on other sites More sharing options...
ibrocn Posted September 24, 2016 Author Report Share Posted September 24, 2016 On 7/25/2016 at 10:35 AM, KyleCT said: Looks like you just need new heater gaskets, call the guys over at hot tub discounts, they will have everything you need. Kyle Thank you KyleCT! I finally found the right heater gaskets. I installed them last weekend and haven't had any leaks. Quote Link to comment Share on other sites More sharing options...
