hoth2o Posted May 17, 2012 Report Share Posted May 17, 2012 What do you use to neutralize hydrogen peroxide in pool water? Quote Link to comment Share on other sites More sharing options...
chem geek Posted May 18, 2012 Report Share Posted May 18, 2012 Hydrogen peroxide and chlorine neutralize each other. So if the hydrogen peroxide was added to a pool with chlorine, then there is probably none left. Just add chlorine and as soon as you are able to hold a Free Chlorine (FC) reading, there will be no hydrogen peroxide left in the water. HOWEVER, if you are using a Baquacil/biguanide/PHMB pool, then do NOT add chlorine to it. In that case hydrogen peroxide is supposed to be in the water as it acts as the oxidizer in such pools. Chlorine is incompatible with such pools and will react with the Baquacil/biguanide/PHMB to give a cloudy colorful mess, though eventually with enough chlorine is the way to convert such a pool to a chlorine pool. Quote Link to comment Share on other sites More sharing options...
