cbradford435@yahoo.com
Pro form saturn model 2003 hot tub
4 posts in this topic
I have a hot tub that I thought the heater went out since it was only 80 degrees.. Bought and installed a brand new one and nothing.. Except I turn on jets and than the heater light comes on and it seems to be heating .. I got 8 degrees in 30 minutes .. Only with jets on... Why ???
Share this post
Link to post
Get a Free Hot Tub Quote
Do you get any error messages when the jets aren't on?  The heater won't come on unless water is moving, so that explains what you're seeing.  The question is why doesn't the pump run on its own when you don't press the Jets button.  Is it programming or breakdown?
What kind of tub is it?  How old?
Also, 8 degrees in 30 minutes is a lot of heating, most 220V tubs are lucky to get 6 degrees in an hour.
Share this post
Link to post
Hi there,
1. No error message
2. When it isn't on high and it's on regular flow, pumpmis running as if heater is on but no heat .. heat light is also not on in that mode.
3. Tub temp said 39 when I started it up, than 45 in 30 minutes, maybe some of he inside water that was sitting in pipes were a tad warmer .
pro form spa Saturn model 2003 balboa parts and circuit board
Share this post
Link to post
If you're getting heat on high flow and not low flow, it could be you're not getting good water circulation.  Try removing the filters, just for a few minutes, and see if the heater will come on when you're at low speed.  If it does, your filters are dirty.  That, by the way, is one of the most common causes of "no heat."
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
