Balboa M7 2000Le Heating Issue
  • Please log in to reply
3 replies to this topic
#1 bprice
bprice
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 08 May 2012 - 05:07 AM
So to who ever had read my last post I did get that fixed and added the solution on that post,
Now have a new issue, when we got the circulator put going we bled the l lines but guess we did it in the wrong spot, we bled the line right at the ciculator pump. So when we turned the hot tub on everything was looking good I had my hand on the heater tube and it was getting hot quick so we disconnected it about 30 secs after powering it on. There was flow coming thru but did not like how it heated up so I bled the line right by the heater tube and there was air in the line and I heard the water sizzle on the heater element. I spoke to balboa about this and the support tech told me that should not be anything to worry about it should be fine. so we made sure everything was bled and powered the hot tub back on and everything is working fine great flow through the circulator pump all jet pumps work and the heater light is lite up.
But after running all night it did not heat, are those heater elements that sensitive could they burn up that quick or should I check something else out before replacing it?
As always thank you for all your responses
#2 Spanky
Spanky
    Spa Savant
  • Members
  • PipPipPip
  • 234 posts
  • Gender:Male
Posted 08 May 2012 - 06:48 AM
You may have experienced what is known as a "Dry Fire", where the heater element is energized without water flow. Your statement of "Sizzle" is a tell-tale sign of this.
You can check the heater with an ohmmeter. The normal DC resistance should be about 10 - 30 ohms, but dry fires tend to be catestrophic.
I'm a bit suspicious about your flow pressure switch because if it were working properly, it should have prevented the heater from energizing without water pressure.
#3 bprice
bprice
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 08 May 2012 - 07:42 AM
Yea you would think that should of protected it but it didn't, this is a brand new pack.
#4 countspacula
countspacula
    countspacula
  • Members
  • PipPipPip
  • 133 posts
  • Gender:Male
  • Interests:fixing hot tubs
Posted 19 May 2012 - 05:31 PM
First, an M7 pack doesnt have a pressure switch. They will dry fire though, flow or not. The heaters in new balboa
Packs are quite sensitive to this. The only downfall of the M7 system is that it will dry fire the heater (WHEN THE HEAT
LIGHT IS FLICKERING BEFORE BECOMING SOLID) the pack sometimes will do this over and over til the element is
Toast.
