Aquatic Industries Heater/pump Operation Question
  • Please log in to reply
2 replies to this topic
#1 Superfly1
Superfly1
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 16 April 2012 - 07:12 AM
New to spas, I have an Aquatic Industries tub with the Hercules control, when running it on the timer, the pump will shut down but the heater continues to run, is this normal to have the heater run with out the pump circulating water? I have run the spa up to temp and the heater does shut off, just concerend about leaving it run with no circulation? I have verified the pump is shutting off, not on low speed.
Aquatic
Model 7070-L
Serial 1096043
#2 Dr. Spa
Dr. Spa
    Advanced Moderator
  • Moderators
  • PipPipPipPipPip
  • 2,430 posts
  • Gender:Male
Posted 16 April 2012 - 11:15 AM
There's probably a problem with the pressure/flow switch...The heater should NOT run without the pump running.
What the heck do I know, I only started in this industry in 1981, and retired from it after 33 years.
From service tech to co-owner of Roberts Hot Tubs, manufacturer of traditional wooden hot tubs & spa covers.
If you can't sell it on ebay, it may not even qualify as landfill.
#3 Superfly1
Superfly1
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 18 April 2012 - 09:42 AM
PSI switch adjusted too high, problem solved, thanks!
