Flagstone Coping Scratches From Contractors
  • Please log in to reply
2 replies to this topic
#1 workinallthetime
  • Members
  • Pip
  • 2 posts
Posted 25 August 2008 - 06:37 PM
i'm nearing completion of my pool, my builder has been great, i've noticed that from the time the flagstone coping went in, it has recieved numerous scratches from the contractors whove done work after the coping was installed, namely the decking, when i say scratches i mean some rather large marks from what looks like other stone dragged over the coping, since i'm nearing the completion i'm wondering is this something that is easy to fix/replace before the final plaster, or is this typical , it seems more care should have been given to the coping
#2 AZPoolBuilder
  • Members
  • Pip
  • 6 posts
Posted 30 July 2009 - 05:55 AM
This is right up my alley..... But, i've always been a big advocate of "the custom is always right" FOR THE MOST PART. First, just ask your pool builder to see what they can do. Explain that it bothers you, and you would like it to look like it was originally installed. A good swimming pool company will usually address ALL of your concerns, no matter how trivial.
Now here's the challenge. Flagstone is a soft stone, so, it's going to scratch & degrade over time. In fact, i've seen some flagstone copings literally FLAKE away in layers... Flagstone is made of lots of small layers of sand, compressed together over time. It's actually pretty easy to buff out, but it then creates a more noticeable area that is smoother than the other stone. So, in my opinion - it's better to leave it, and let it buff naturally as you use the pool. It doesn't seem like replacement is warranted, but that's the worst case scenario (and they won't like you for that.....but, you are the customer) Most pool companies are NOT stone experts, so make sure these guys test a small area if they offer to fix it. Make sure you like the fix before they do all the scratches. Once buffed, there is no going back!
While I'm thinking of it, make sure you DON'T have a salt system! Salt and Flagstone don't mix. The salt crystals are 4 to 5 X larger in dry state, than in liquid. So, these guys get into the flagstone very easily, dry out, expand, and will actually turn the flagstone to DUST over only a few years. we've been semi-succesful with sealants, but sealants wear down.
#3 quantumchromodynamics
  • Members
  • PipPipPipPipPip
  • 1,469 posts
  • Gender:Male
Posted 30 July 2009 - 09:26 PM
Yes, you should ask the contractor to make it right, to your satisfaction. You paid extra for that type of coping, and you should expect that the workers would be careful not to damage it.
As for sealers, I like Vinyl Supreme from Seamco Surfaces.
You can't manage what you don't measure. Get a good test kit. I recommend the Taylor K-2006 for chlorine or the Taylor K-2106 for bromine.
